Chaos (Axyz) Anima low quality texture render (shading graph work around)
  • Chaos (Axyz) Anima low quality texture render (shading graph work around)
    I often use Anima people in my 3dsmax scenes.
    I notice that the textures are of poor quality when I turn on the final render.
    As soon as I turn off 'Shading Graph' in Vantage the textures are better but then other problems arise such as burcon-tile that is no longer visible.
    Is there another way to get the textures of anima better?​
    Hi richard_geleijnse,
    This looks like a normal map issue for me. Can you try to disable Normal map rendering from the Render settings tab > Advanced > Material rollout > Normal map checkbox to see if it makes a difference?
    Alexander
    Alexander Atanasov
    Chaos
      thanks for the quick response.
      i tested it and it is indeed a normal map issue.
      is there a way to isolate only the anima people from normalmap?​
        Originally posted by richard_geleijnse View Post
        Same problem here...
