RailClone Proxy objects
  • RailClone Proxy objects
    Hello
    I set up a RailClone preset that arrays cars for large car park scenes. Not wanting to have all the cars loaded in the scene, as full meshes, I used Proxys. These render fine in CPU Vray, but in Vantage the cars only show the proxy mesh. Is there a way of getting this to work?
    Does it render correctly if you render it with V-Ray Standalone (choose Export and render in the .vrscene export dialog) ?
    If not, this is most likely a V-Ray for 3dsMax export issue, not a Vantage issue.
    In any case, we will need a scene to figure out what the issue is.
    Are you using V-Ray Proxy or some kind of 3dsMax Proxy ?
    Greetings,
    Vladimir Nedev
      Hi Vladimir - I don't have access to Vray Standalone in my office to test that out, however I'm just using regular Vray Proxies. As a test - I made a Railclone row of proxied Teapots and the same thing occurs
        Can you attach this test scene here for us to test with ?
        Greetings,
        Vladimir Nedev
