I'm running into issues with my project. Looks like the geometry that is being hidden with FP edge option is creating some shadowing issues. See attached image. How do I fix this?
Forest pack edge issue
What versions of Forest Pro, V-Ray and Vantage are you using ?
Can you send us a simplified scene that shows the issue ?
Greetings,
Vladimir Nedev
Originally posted by Luma3d View Post3ds max 2025, latest vray 7 and Vantage 2.7.1. I resolved this issue. It was because my path material was using a vray dirtmap and I did exclude the forest pack assets.
Greetings,
Vladimir Nedev
- Likes 1
Originally posted by wagner_augusto View PostSame here...
Max 23
Forest 9.1.6
Vantage 2.7.1
Greetings,
Vladimir Nedev
Originally posted by vladimir.nedev View Post
Are you using VRayDirt as well ? If not, please provide an example scene showing the issue.
Greetings,
Vladimir Nedev
Greetings,
Vladimir Nedev
3 Photos
It's just a plane with the lawn preset from forest pack. I've manage to find a workaround. If i save the config file from vantage, close the software and live link, reopen and merge the configs, forest edge works fine. So i believe this is something with vantage.
Greetings,
Vladimir Nedev
The fix will be in our next Vantage release. (Incorrect back face culling for geometry instances affected by edge trimming (until their material is changed or a config file is loaded)
Greetings.
Vladimir NedevLast edited by vladimir.nedev; 02-05-2025, 08:16 PM.Vantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
