live link don't work
  • live link don't work
    When I use the initial live link to Vantage, the standalone version of Vantage opens with empty scene.
    Are you able to export the scene as a vrscene file with no errors?
      Yes the export works with no errors.
        Are you "starting the server" (in the Live Link menu) within Vantage?
        Then clicking "Initiate a live link" in 3Ds Max?
        Dean Punchard > Head of CGI at HUB
          I couldn't quite understand the issue. The "standalone version of Vantage" is just Vantage because there is no other version. Are you using live link or a vrscene file? Both were mentioned but they are mutually exclusive.
          Nikola Goranov
          Chaos Developer
            I use Live Link.
            I found a way to solve this issue. I must activate distributing render manually and play the render in the frame buffer, then the live link is active and ready to use.
