Animate doors opening
  • Animate doors opening
    I am trying to animate the opening of doors in a vantage animation. I have the doors opening in max. I have saved the vrimg file and imported into vantage. At that point I can see the doors opening. However when I add the camera's used to approach the door using live link the animation is overwritten. I can see the doors opening behind the doors that are staying closed though. Are there any tutorials or instructions on how to do this?
    Hi george_chianese1,
    What do you mean by "I add the camera's used to approach the door using live link"? If you are in Live link the scene in Vantage is the same as in Max so both the door and camera animation should work. I don't understand why are they 2 instances of the doors. Can you please share a simple scene or record a video of your workflow?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hi Alexander, thanks for your reply. I tried it again and it looks like I got it to work. Do you have any tutorials on animating with vantage available?
