Render nth frame and frame ranges
  • Render nth frame and frame ranges
    Hi guys
    We're livelinking from max and rendering an animated cam. It would be great if we can render nth frame or specify which frames to render, similar with frame renders and nth frames from max.
    We though perhaps we can within Vantage just use the still render, add it to que, then move timeslider in max to the next frame we want, add it to the qeue and so on, but that doesnt work as it renders same frame
    Kind Regards,
    Morne
    This is very useful
      Hi Morne,
      We have this request and is in our To Do list but no development has started yet. You could use what you suggest as a workaround but you have to create a camera for each frame in Vantage and then in the Render setup window specify those cameras in the camera drop-down(usually it says <current camera>). Then you can add each individual created camera to batch render them:https://drive.google.com/uc?id=1mbMK...4Nk9JKKoNimEFb
      Alexander
      Alexander Atanasov
      V-Ray for Unreal & Chaos Vantage QA
      Chaos
        Originally posted by Alexander.Atanasov View Post
        Hi Morne,
        Alexander
        Thanks. That is a bit painful, but at least its a temp workaround for now...
        Looking forward to the proper implementation
        Kind Regards,
        Morne
          Hi Morne,
          Hi Alexander!
          Is it still on the To-Do-List ? Would be a very handy function
            Yep this is very strange, any reason why nth frame isn't added by now, would be incredibly useful so as to check animations quickly, thanks again for your fab efforts
            Jason
            AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.5796, 3dsmax 2025.2, Vray 7 Hotfix 2, Vantage 2.7.1​
              Hi all,
              Yes, it is still in the To Do list. Will try to bump the priority to get higher in the list.
              Alexander
              Alexander Atanasov
              Chaos
                Thanks Alexander.Atanasov, would be a life saver as we could preview draft movies much quicker.
                Kind regards,
                jason
