Dear Vantage team
Vantage has been an amazing tool to fast animate cameras and showcase architectural project while navigating.
It could go a step further if you can add more cinematic ways to film in Vantage. Like orbit around object is not now possible inside Vantage. or if you can add camera shake. of course all these can be done manually inside max but I consider Vantage the perfect tool to fast , intuitive cinematography..
A step even further can be the following.
IF you can enable VR preview inside Vantage (with minimum settings , no GI, no reflections,) using oculus rift or quest, just to capture , record camera using controller ( using stick to change fov, dof...) and record this physical way of filming your project in Vantage, so that you can then render.
