Would you like to consider setting up some effect materials for Vantage?
  • Would you like to consider setting up some effect materials for Vantage?
    For example, rain and snow.
    Automatically wet the covered ground.
    If you only use VRayBlend material, it will be more troublesome. Will you take advantage of real-time rendering to customize some effects that can be generated quickly? Some user-defined parameters are also provided.​
    HI q976431,
    We are considering adding such materials, e.g. animated water, and will probably come at a later time. Thank you for the feedback, I will log in your request in our system.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Originally posted by Alexander.Atanasov View Post
      HI q976431,
      Alexander
      That's good news
      if possible. It is desirable to consider the wetting effect of objects in contact with water​
