bump/normal map get weak when denoiser enabled
  • bump/normal map get weak when denoiser enabled
    Hello,
    When I enable denoiser, I get a weak bump/normal map effect, which will be worse when I move camera farther.
    If denoiser is disabled, the bump/normal map is fine, but there is much noise, even I set Noise threshold to zero.
    Is there any way to fix this?
    Thanks.
    Hi baoxiaohe_developer,
    The only current way, using the denoiser, is to render with high Sample values(1000+, scene dependent). The Nvidia AI denoiser tends to blur textures with very high frequency as it considers them as noise.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
