Hello, I would like to know if you are working on getting Chaos Vantage to use DLSS because in the waters this engine enters it is simply a must to do. Thanks in advance!
Dlss 3 ?
Hi Martin,
DLSS is something that we tried internally but didn't provide much benefit. We could revisit it with the new release of DLSS 3 to see if something has changed and could useful to us. We will let you know if there is such development.
AlexanderAlexander Atanasov
V-Ray for Unreal & Chaos Vantage QA
Chaos
Alexander.Atanasov npg Thanks for the replys! I asked this question because it is used in D5 render and it is also used in interior and exterior by designers like us not for games and it supports Dlss. The big difference is that there the preview remains at maximum quality and DLSS additionally helps to predict the next frames, therefore the animations are times faster there. RTX4090 and 4080 cards would be good benchmarks to test DLSS again. My main wish is to look the livelink in max quality in 60fps with 4090 like in D5 render. I know that In D5 render there you are using Ray tracing but how do you make the gpu to use Path Tracing in the title of vantage clearly says Chaos Vantage – Pure ray tracing in real-time.Last edited by martin_petkov; 15-12-2022, 02:45 AM.
npg ok D5 is ray tracing in real time and path tracing in final render thats why there are differences but in the title of chaos vantage is said that is pure ray tracing in real time or its not? Why you cant add dlss too like in D5 and is it possible for the people with high end gpus to make an option to lock the fps to 60 and automatically to get the best possible quality and there is Displacement too? Thanks for all the info I appreciate it!
