That it is in the TO DO list but cannot say when i will be implemented. As a sort of a workaround if you use a .vrscene you can drop the imported cameras in the camera track (without interpolation between them) and render out the entire sequence: https://drive.google.com/file/d/1exo...usp=share_link . However this will not work if you use 'Render animation with Chaos Vantage' workflow.
