Ambient Occlusion
  • Ambient Occlusion
    Include option to render Ambient Occlusion as a separate Render Element when we don't want it baked in under Environment settings.
    Hi, thanks for posting. Could you explain your workflow in a bit more details? You need the Ambient occlusion as render element for animations or still images? Do you plan to add it in post?
    Vladimir Krastev | chaos.com
      Hi, AO render element needed for still images so we can vary the opacity and paint out unwanted areas in post.
        Hi, thank you for sharing. I logged you suggestion in our system as a feature request under LAV-1544.
          Is this feature already implemented?
          Can we render AO as Render Element ?
            Hi filip_s,
            No, AO as a render element is not implemented. Please vote for the idea here in the Idea Portal https://chaosvantage.ideas.aha.io/ideas/VANTAGE-I-93
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
