when we create images with diffeent aspect ratio and we put them with transition in timeline, it would be very nice and cinematic if the format is animated as well,
For instance if you start with a landscape format and then you transition to a portrait one it would be nice to have the black bars left and right to be animated so that the transition from landscape to portrait would be smooth.
THis is a technique that is being used in cinema a lot.
In archviz is very important because very often architectural scenes are much better represented in portrait format
Thanks in advance
Thanks in advance
