Dear VAntage team
Anima 4D is one of the most crucial elements to enstill life into our animated movies.
Now that you acquired AXYZ can you please make it so that we can move anima 4d people inside vantage. Now when you export anima 4D they come locked to the place where you imported.
This is very inconvenient when you want to do composition in vantage
And the ultimate goal would be that we just open anima drop window and drag and drop anima 4d straight to Vantage.
This last possibility will totally REVOLUTIONIZE our workflow and end result of our films, because it will make it fast and intuitive to test different characters in different places until you find those that really help you tell a story.
Now it is VERY laborious to place them correctly in 3ds max (3ds max viewport almost not responsive when anima 4D and live link) and then export them in vantage (animated vrscene taking tooooo long and being veeeeery heavy) and then in vnatage they come locked.
The solution to render animation with live link not actually a viable solution , cause of 3ds max viewport being very laggy and adding like 10 sec to refresh each frame before vantage renders this frame.
Please consider this as VERY HIGH priority
Thank you very much
Thank you very much
