bw masks of selected objects in vantage viewport
  • bw masks of selected objects in vantage viewport
    Dear Vantage team,
    Now that you implemented multimatte render element in vantage I think it is easier to make the bw mask of selected objects in the viewport with just one click.
    First if you can bring the multimatte element in the viewport , instead of having to render the render element, (like all render elements that you have right now in the viewport)
    then if you can enable in the multi matte element one button that creates a bw mask of selected objects instead rgb.
    In general the ultimate workflow for archviz images will be that you just select few objects you go to viewport render elements and there you find a bw mask of the selected objects, which you just ctrl C copy and past to photoshop to keep editing your image.
    Thanks a lot
    Hi, thanks for posting. We have a similar idea that is already logged as feature request (LAV-1623). I will add you thread to it and raise the priority.
    Vladimir Krastev | chaos.com
