renderpeople volumetric 4D
  • renderpeople volumetric 4D
    One benefit of renderpeople volumetric 4d people compared to axyz anima 4d, is that you can export very fast into a vrscene, and then you can drag drop this vrscene in vantage standalone.
    This is extremely helpful when workign on an archviz film, cuase after you setup your scene you just drag drop actors and then you start filming (rendering)
    Can you make the same possible with ANima 4D from axyz (specially now that you are one company)
    Then there is a problem with renderpeople volumetric 4D the walking ones, cause when you export them they are locked in vantage meaning you cannot move them in a different position inside vantage.
    CAn you please test yourselves one walking renderpeople 4D and let me know if there is any workflow that will allow me to move the exported animated 4d people freely inside vantage
    Thank you very much in advance
    Hi, thanks for posting.
    You can do the same with Anima4D, using 3ds Max and the vrscene exporter.
    Vladimir Krastev | chaos.com
