Dear Vantage team
The best way to animate a field of wheat, grass, flowers, vertical garden as if animated by the wind is with FP animate rotation Y with noise map.
Even though it renders perfect with live link, you cannot save the animated scene as vrscene and render it with vantage.
Can you please fix this and make it work with vantage standalone.
At the same time can you fix the following as well:
when you scatter animated objects with FP there is the possiblity to offset frames randomly, but unfortunately is not rendered with vantage or GPU.
