Vantage + 3dsmax output settings
  • Vantage + 3dsmax output settings
    Hello,
    I simple one. Can Vantage inherit 3dsmax´s output resolution?
    I am working on several projects that has different resolutions and aspect ratios, but i have to manually set them in Vantage.
    Please!
    Hi brunonz,
    Vantage does import camera resolutions set from 3ds max. Which V-Ray and Vantage versions are you using? Can you send us sample scenes to test?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hello,
      I am using latest of everything. Here´s a snapshot, it ignores the resolution (and not in this case, ratio). I have to set render sizes everytime i need to render in Vantage.
        The render dialog remembers the last used resolution. If you select a specific camera it should load the resolution stored for this camera.
        Nikola Goranov
        Chaos Developer
          Yes, it´s overriding what i want from the 3dsmax resolution. I don´t want to remember what was used last.
          Can you add an option on future builds?·
          Tks
            Hi brunonz,
            In the Resolution rollout use the <from camera> camera preset. This should fetch the resolution set from Max.
            Tell us if it works for you.
            Alexander
            Alexander Atanasov
            Chaos
              Yes, that works.
              It has some lagging to update the resolution between Vantage and Max but works overall.
              Tks!
