When will the noise map for 3dsmax be available, I hope it will come in the next update.
Is 3dsmax noise map coming
You mean for bump mapping ? It should already work for everything else.
Greetings,
Vladimir Nedev
Originally posted by serdar_turanl View Post
I apologize, I gave incomplete information. I really want to run this map in the bump channel.
Greetings,
Vladimir Nedev
Wouldn't it be nice if max supported its own noise map and smoke, wave maps like this one?
Greetings,
Vladimir Nedev
Sometimes, personalizing the map becomes necessary. In my opinion, modifying it parametrically makes more sense than searching for a map.
Greetings,
Vladimir Nedev
what's in the next version
Greetings,
Vladimir Nedev
So is there a date?
Greetins,
Vladimir Nedev
Wouldn't it be nice if max supported its own noise map and smoke, wave maps like this one?Dean Punchard > Head of CGI at HUB
Originally posted by suzanne_doherty View Post
Just to add, you can render out a map directly from the material editor. So the workflow is to create your noise map, render out to jpg at a high resolution, then plug back into your material. Works well.
