ACES Tutorial Confusion
  • ACES Tutorial Confusion
    https://docs.chaos.com/display/VMAX/...Workflow+Setup
    https://docs.chaos.com/display/VRAYH...Workflow+Setup
    Who rewrote the aces v1.3 base? Have the updated staff actually tested it?
    In cg-config-v1.0.0_aces-v1.3_ocio-v2.0.ocio, "sRGB" cannot be selected for Display Device. Also, "ACES 1.0 - SDR Video" cannot be selected for ViewTransform.
    The Maya ACES tutorial has been modified based on v1.2, see the thread below.
    https://forums.chaos.com/forum/v-ray...-aces-again​
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    I don't think there is a need for a "Docs & Help Center" category on the Chaos forums.
    It seems that it is better to point out in each application forum.
    The documentation is written by the person in charge of each application, and it seems that the person in charge doesn't read this forum.
    oakcorp.net
    v-ray.jp
      Works fine for me. Following the exact same environment variables and ocio config.
      Handling of the documentation is done by a separate team, which works tightly with other teams. This forum category is meant to discuss the docs or report issues to them directly.​
        Thank you for your advice.
        Certainly, aces-v1.3 ocio-v2.0 can be used if specified via environment variables.
        However, why can't it be set if the OCIO file of "cg-config-v1.0.0_aces-v1.3_ocio-v2.0.ocio" is specified in the GUI without using environment variables?
        There is some confusion here.
        Thank you for informing us.
        I check the document daily for updates. Let's continue to work together to make the documentation better.​
        oakcorp.net
        v-ray.jp
          However, why can't it be set if the OCIO file of "cg-config-v1.0.0_aces-v1.3_ocio-v2.0.ocio" is specified in the GUI without using environment variables?​
          The options are correctly displayed on my end even when loaded manually. There must be something going on with the config file on your end. Check the "active_displays" and "active_views" in the config file - if something is missing you can manually add it.
            I'm sorry that it doesn't make sense.
            This is simply due to the old setup screen in Houdini's ACES tutorial.
            If use ACES v1.3, User won't get the same selection as in this screenshot.
            This question was asked by my V-Ray Houdini user.
            oakcorp.net
            v-ray.jp
              I see. I'll notify the docs team to update the image.
