Licence server install
  • Licence server install
    Hey guys,
    Hopefully an easy question to answer but couldn't see it in the help docs (unless I missed it)...
    We've recently purchased VRay Next and are looking at installing it today. Do I need to make sure every workstation/node has the licence server installed, or do I only do this on one machine (as per forest pro/railclone licence server) that can be seen by all other machines?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    Not really - you can set up 1 or 2 machines for license servers and get licenses from there - for example, if you have a license server with dongles - you can just use the same computer. It's a neater setup than having the license server on each machine and generates less network overhead.
    You can see some example setups here - https://docs.chaosgroup.com/display/...License+Server
    Ivan Slavchev
    SysOps
    Chaos Group
      Ahhh, excellent. My fault as I hadn't seen that page.
      Thank you!
