Could not obtain a license (-200)
  • Could not obtain a license (-200)
    Vray is displaying this message, happened suddenly while working on a file. Vray and vrlserver are both updated to the latest version, license info is correct in the edit/set license server dialog.
    There was some latency in the backend for several minutes, should be OK now. Check if you see your license when you navigate to http://localhost:30304 on the license server machine and if yes - restart 3ds Max if you still have the issue.
    Ivan Slavchev
    SysOps
    Chaos Group
      As everything was working fine, out of a sudden I got the same -200 error. I tried restarting my PC several times, reinstalling Vray, WibuKey drivers and the license server. http://localhost:30304 gives me an error: "This site can’t be reached". I checked the Windows services and VRLicense was stopped. I tried to start it but it won't let me - "error 1053".
      Aleksandar Mitov
      www.renarvisuals.com
      office@renarvisuals.com
      AMD Ryzen 9 9950X 16-core
      96GB DDR5
      GeForce RTX 3090 24GB + GPU Driver 566.14
        Please try the following:
        1. Uninstall the V-Ray/Chaos Group License Server from "Control Panel" -> "Programs and Features"
        2. Delete the folder "C:\Program Files\Common Files\ChaosGroup"
        3. Download and install this version of the license server:
        https://download.chaosgroup.com/down...dalone-451-adv
        4. Check if you are able to reach http://localhost:30304 - if you do please proceed with the next step. If you do not please skip the next steps.
        5. Download and install this version fo the licenses server:
        https://download.chaosgroup.com/down...dalone-512-adv
        6. Check if you are able to access the page at http://localhost:30304
        If you are still not able to access the license server web interface please archive the folder "C:\Program Files\Common Files\ChaosGroup\logs" and send it to support@chaosgroup.com so we can investigate further.
          Thanks, Mihail. The Problem is solved now.
          Aleksandar Mitov
          96GB DDR5
            Mihail Kuzev Thank you for that solution - it works!
