Two instances of max open, but one license?
  • Two instances of max open, but one license?
    How is it that I can open a second instance of 3ds max and it can't find the licensing server but the first instance work just fine?? I've been used to working with 2 and sometimes 3 instances open at a time with no issues until today.
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2023.3 Update
    V-Ray GPU 6 Update 1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    You lost connection to the license server - max stays open for 2 hours after dropping it, but new copies opened still check in even if one is open and they won't pull an extra.
    We get our licenses from a server in NYC, and we are in Miami. Happens every now and again.
      That's what I had initially thought. But a check of the licensing server getstatus showed that everything was good. I re-booted and that seems to have fixed the issue. I hadn't run into that before.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        What's the license server's version? Try the latest one if you use an older version, I think there was a bug that was causing license skipping in 5.1.0 /5.1.1 when dongles are used.
        Ivan Slavchev
        SysOps
        Chaos Group
          I'm on 5.2.1 It just did it again, but this time with only one instance of Max 2019.3 running. Restarting Max fixed was the solution.
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            Can you try https://download.chaosgroup.com/down...dalone-522-adv
            Ivan Slavchev
            SysOps
            Chaos Group
