Backburner is skipping jobs due to licensing errors
  • Backburner is skipping jobs due to licensing errors
    I have several jobs in backburner queue. Some of the jobs are causing "could not obtain license" -errors while the others are rendering correctly. Yet the jobs are created on same workstation and that workstation renders the jobs fine alone. I have a sort of a deadline tomorrow for this little walk around, so I would very much like to use all the rendering servers I have.
    Could you please first open the web browser and type into the address "localhost:30304" in order to check if your licenses is enough and the same as the amount of your render slave machines? Also please check if the V-Ray client license settings is set correctly to the machines where this issue appears:
    https://docs.chaosgroup.com/display/...cense+Settings
    Also please confirm if you are able to rednder without Backbburner, but only V-Ray DR? If you can share more infromation of the amount of your machines, your username and screenshots of the issue and V-Ray license server, V-Ray versions installed and 3ds Max version it would be best. You can also write us an e-mail at "support@chaosgroup.com" and provide us with the above sensitive information and link to this forum thread, so we can help you further with your issue. Thank you.
    Stefan Isakov
    Technical Support Team Lead
    Contact Support
    Chaos
      Thanks, I wrote to the support and they suggested a teamviewer session with me. I don't know when I have time to arrange that. Localhost license server is version 5.1.2. V-Ray is 3.7.01 and Max 2020. On localhost, it says license count is negative -1 (2 in use, where's the other?). Why is the count negative and why it shows 2 licenses in use? As far as I know, I'm using only one license in one workstation. However on Render nodes there's 5 licenses available and the render nodes are refusing to render this one and the most urgent job. It render fine other bb entries, those less important scenes.
      I can render the scene in question without any problems in Max UI.
        In the first place, we recommend you update your V-Ray license server up to version 5.2.3 (https://download.chaosgroup.com/?platform=47&product=48), after the update if the same negative values appear, please make sure to send us a screenshot of it. Also please make sure to tell us your username and if you are able to provide as much more information in reply to your last e-mail, maybe we can find a solution and help with the proposal without doing a Team Viewer remote session.
        Stefan Isakov
        Contact Support
        Chaos
          Thanks,
          I installed the update, but it didn't fix the issue.
            Is it possible to provide us with the above mentioned information? it will best if you send an e-mail to "support@chaosgroup.com", and we will try to analize it and help you without the remote session. Thank you.
            Stefan Isakov
            Contact Support
            Chaos
              I checked one more time and found out the reason to be License server could not be reached. I wonder why only one job on the queue is affected.
                It's possible that a specific machine has a problem connecting to the license server. Please message us at "support@chaosgroup.com" and we'll look into it.
                Ivan Slavchev
                SysOps
                Chaos Group
                  None of the servers are connecting with that specific job, while other jobs are connecting normally.
                    I can confirm, it renders old jobs just fine. I haven't yet tried out sending new jobs to backburner queue. I'll let You know what happens when I have next job ready to be sent to backburner..
