Vray Next trial when 3.6 installed
  • Vray Next trial when 3.6 installed
    I have a couple of 3.6 licenses & several render node licenses that I use with Max 2018. I'm wondering if I can install the Next trial & use with Max 2018 or do I have to use the Next trial with a different install of Max, say 2019 or 2020. Thanks in advance for any info you can provide.
    You can install only V-Ray 3.x or V-Ray Next in only one 3ds Max version. But you can install different versions of V-Ray in a different versions of 3ds Max. For example install V-Ray Next in 3ds Max 2018 and install V-Ray 3.x in 3ds Max 2019. You can always roll-back to the previous version if you want. Let me know if you need further information or any assistance.
    Stefan Isakov
    Technical Support Team Lead
    Contact Support
    Chaos
      is this the same for vray 5 beta? (have to uninstall next to use the beta?)
      when the going gets weird, the weird turn pro - hunter s. thompson
        Yes, the V-Ray 5 installer will uninstall previous V-Ray versions for the same 3dsMax version
        Ivan Slavchev
        SysOps
        Chaos Group
