Is it possible? 2 machines asychronously?
  • Is it possible? 2 machines asychronously?
    Hello, quick question, Am i allowed to install the software on 2 machines, but not run them at the same time? Ie Laptop at home, desktop at work? a workflow example, setup scens and test render at home, then send them to the office to render overnight.
    thanks.
    x570, 5950x, 96gb Ram, Gigabyte Turbo RTX 3090, Asus Turbo RTX 3090, 2x Samsung 970 Evo SSD 1.0TB M.2 NVMe , 1000 corsair + 750 corsair PSU's. houdini 18.5 . vray 5.1
    Hello, there is no restriction on how many computers you can install V-Ray and the Chaos license server. The limitation comes from the number of available licenses you have. If you have one license you can use only one machine at a time. So your use case is perfectly viable, as long as you don`t try to run V-Ray simultaneously on your two computers it will work.
    Kostadin Botev
    Contact Support
    Chaos
      Super thank you very much. just what i wanted.
