So the client license settings on workstations and render nodes have a place for three license servers. How can we setup a backup license server? Does this work if we use the Use Licenses Offline option?
Ideally we would have two local license servers, and they both have access to the same offline licenses such that if one local license server goes down the clients contact the second local license server, AND no constant internet connection is required because we have those licenses set for offline use.(Internet only required to periodically re-update the offline licenses).
Does this work like this with two local servers? If not, what method achieves both goals of local redundancy and no constant internet connection required? (Obviously requiring a constant internet connection is out of the question because you are putting your entire organization at the mercy of one connection. Even though we have a backup net connection there is nothing to do if a backhoe cuts the lines running the the building, or a power outage cuts power to both network provider's line amplifiers, etc..)
Is it safe and OK to login in to Online Licensing from two local license servers simultaneously? Will this cause problems? I assume this is how you get a backup license server, but then what to do about borrowing licenses for offline use?
Thanks.
Thanks.
