V-Ray for Mac Studio
  • V-Ray for Mac Studio
    Hello Guys!
    Does everyone know when should be able V-Ray for Apple M1 chip?
    Thank you in advance
    Best regards
    Max
    V-Ray is natively supported on M1/M2.
    Kostadin Botev
    Contact Support
    Chaos
      Originally posted by rainhard_kompatscher View Post
      Hello Guys!
      Best regards
      Max
      Vray runs natively on M1 for over a year.
      3D Scenes, Shaders and Courses for V-ray and Corona
      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
      @3drenderandbeyond on social media @3DRnB Twitter
        Hi guys!
        Thanks a lot for the quite answer...some technical says otherwise
        Max
          Maybe they are not so technical then
            I need another answer/confirmation. If I buy an Apple Mac Studio, works good with Rhinoceros and Vray?
            Sorry for my stupid question, I'm not a computer technician, and on that point I don't trust on our technician.
            Max
              The problem is not M1 compatibility, the problem is that there is no MacOS version of Vray for Rhino.
              https://forums.chaos.com/forum/chaos...or-rhino-6-mac
              On other supported platform works well though, Cinema4D, Sketchup etc
                Thank you Sirio76 for your reply.
                Did you know if Chaos is still working on that point?
                  Dear rainhard_kompatscher, hello.
                  The topic was discussed at different places, but please refer to this post which explains the situation quite well.
                  Since it is at V-Ray 6 beta forum, will paste the text also here to be sure that it will be visible to all users.
                  The answer is from Nikolay Bakalov, the Lead Developer of V-Ray for Rhino:
                  Originally posted by jason_vayanos View Post
                  From what I understand, the V-Ray for Rhino and V-Ray for SketchUp are similar applications
                  yes, but not in terms of host application APIs. They are completely different things. V-Ray for SketchUp and V-Ray for Rhino share all the cide, except the hostapp SDK dependant part
                  Would love to hear what Chaos thinks, and if there are plans for support.
                  V-Ray itself supports Apple Arm chips, which is evident - C4D sketchup, maya, houdini...they all run natively on the M1/M2. Our plans of Rhino on Mac exist since 3-4 years ago. However the problem is the Rhino API. Historically V-Ray for Rhino is written on C++, using the Rhino C++ SDK on Windows. On Mac, however, McNeel do not offer a C++ SDK, but only .NET/Mono one. Hence the language we must use is C#. None of the already existing C++ code could be reused, and both SDKs have absolutely nothing in common. This means we need to rewrite everything on another language and against differnt SDK, that could potentially have fewer features. Then we need to support both implementations.
                  this is not quite feasible.
                  We know that McNeel have written their own Mac plugins on C++, hence such SDK exists. We have asked McNeel several times about publishing the SDK one way or another. The answer has always been 'No'
                  As you can see, if is not that we don't want, quite the opposite, however on these condirions, we don't really have a choice
                  Tsvetomira Girginova | chaos.com
                  3D Support | contact us
                    Dear Tsvetomira Girginov,
                    thanks a lot for the answer and the advice about the Topic!
                    Thanks also to everybody for the support!
                    Have a nice day!
                    M
                      You are welcome!
                      Contact us again if needed.
                      Wishing you all the best.
