nuke V-Ray
  • nuke V-Ray
    When connecting the viewer to a vrayrenderer node I get this message> V-Ray initialization failed:could not obtain an interface license ( -200)
    does anyone knows what is this? thanks
    Hello Tomas,
    The error that you receive "Could not obtain license (-200)" is related to a connection issue to the V-Ray License Server.
    Please check the following:
    1. Is the V-Ray License Server running - if it is installed locally on your machine it should be located at http://localhost:30304 . If you are not able to access the web interface please try reinstalling - you can download the latest standalone installation from here:
    https://download.chaosgroup.com/license-server
    2. In case the license server is on a remote machine please make sure that it is pointing to the correct Hostname or IP address:
    https://docs.chaosgroup.com/display/...cense+Settings
    3. Check if there is a firewall/antivirus application that might be blocking the access to the V-Ray license server on port 30304. If necessary please add exceptions for it.
      Thank You muhail, I downloaded the .exe file, but at a certain point it asks to enter User Name and Password
        I got it running. Thank You.
          Glad that it is working for you!
          Just a side note - the username and password are for the Online licensing activation. The credentials are the same that you use for chaosgroup.com website.
          If your licenses are on a dongle it is not necessary to activate it. Also if you skip that step during the installation you can activate the Online licensing later at http://localhost:30304
