What exactly is the file 2.50.L30 in download section?
2.50.l30
Thank you for details.
If i understand it right
I have one workstation where I personaly work with GUI + 4 computers as render nodes. I will install Vray2.50.L30 and Vray 3.6 on the same time on the same machine and on other render machines install render nodes for Vray2.50.L30 and Vray 3.6. When i need to render some older Project for bilboard in 10K f.e., i use Vray2.50.L30. After that i switch without new installation to 3.6 in 3ds max via assign renderer dialog to vray 3.6 and continue to work on new projects
What i cant, is to work on one machine on 3.6 and in same time to open 3dsmax on other machine with Vray2.50.L30. It means all the time i have one license, no matter which one, just I need to be sure, if both are installed contemporary and i just choose which one need to use; or; I have allways uninstall vray 2.5, install 3.6 depending on which version i need to work and vice versa?
Excuse me for so silly questions, but i need to know exactly, what i can expect before i upgrade license in my USB dongle with Vray 3 license, because I need so far still work in 2.5. I'm rightful to use vray 2.5 or 3.6 on workstation+5 rendernodes - right? The question is , if I have to install everytime matching vray, or i have installed it simultanously and choose right renderer in 3dsmax?
Roman
