Hello,
I recently bought a student license of V-Ray for Rhino. I was trying to set up a render node with Vray Swarm, but I the node always turns unstable when I try to use it for a render.
1) First I tried to install only Vray swarm on the render node using system license configuration. But it didn't work.
2) Then I installed Rhino and vray (with license server and vray swarm) still using system license configuration and it didn't work either.
3) Then after reading some posts in the forum I switched the "use system license configuration" off using the other computer IP address (192.168.0.105:30304) but it doesn't work either.
The logs show this error:
error: Could not obtain a license (1002): All the licenses for this product are currently engaged.
I can't find anywhere whether the student version has the possibility to use renders nodes. Does it have? If yes, what am I doing wrong?
If not, can I use the other computer to render and not the one I'm working on? How do I do that?
Thanks
Thanks
