Phoenix FD Licensing questions
  • Phoenix FD Licensing questions
    Hello,
    What is the difference between the $97/yr. long-term simulation rental and the $390/yr. rental? Perhaps $390/yr includes support for additional BB nodes and $97/yr. is Workstation only?
    Thank You.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    The 390 one is a Workstation license package, meaning that you get 1 GUI and 1 Simulation license. The $97 one is an additional simulation node license. It allows you to run more than 1 simulation on more than 1 machine simultaneously - e.g. Sim1 on PC1 and Sim2 on PC2.
    You can check the following link for more information - https://docs.chaosgroup.com/display/...ation+Licenses
    Ivan Slavchev
    SysOps
    Chaos Group
      Sounds like the GUI license is a requirement? So the more Sim licenses you have, the faster the render(s)? If I were creating a still image with water splashes for instance, could I get by with 1GUI and 1 Sim license?
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Yes, you will need at least one GUI license. More Sim licenses mean that you will be able to iterate faster, the rendering part is handled by V-Ray or the renderer you are using.
        You should be good using 1 GUI and 1 Sim license.
        Georgi Zhekov
        Phoenix Product Manager
        Chaos
