Trying to install vray on my system I have a dongle, can't launch license server. Any help will be greatly appreciated. Thanks
What does this mean "One of the following licenses are required WibuKey 250897: 775810 Failure reason WibuKey API error ocurred ( Error 128) /
It appears that you are trying yo run an older version of the license server. This error occurs if:
1. The Wibukey USB dongle is not plugged in.
2. The Wibukey drivers are not installed.
3. The latest (6.40) Wibukey drivers are installed (they are not compatible with the older versions of the license server)
Please install the latest version of the license server:
https://download.chaosgroup.com/down...dalone-512-adv
Please note that this version runs as a service and it is not necessary to start it manually. After the installation finishes please check if the dongle is recognized at http://localhost:30304
If the license server is not able to detect the dongle please perform a clean install of the Wibukey drivers ( system reboot required ):
https://docs.chaosgroup.com/display/...Dongle+Drivers
What's your OS version? Also - when are you getting the message? This usually happens when you have new drivers and an old license server version installed. Make sure that all older license server versions are uninstalled and try reinstalling the latest one - https://download.chaosgroup.com/down...dalone-512-adv
Did you do a clean reinstall of the drivers - https://docs.chaosgroup.com/display/...Dongle+DriversIvan Slavchev
SysOps
Chaos Group
