this morning I get a Vray could not initialize UI license -200 The ChaosGroup License Server cannot be reached
  • this morning I get a Vray could not initialize UI license -200 The ChaosGroup License Server cannot be reached
    What is the fix - I need to do some rendering today in modo with vray next.
    Also http://localhost:30304 is down.
    Also I tried to make an edit to add http://localhost:30304 is down and the forum says I am not authorized to access my post to edit it!
      Did you tried to make clean re-install of the V-Ray license server and see if the web page "localhost:30304" or "127.0.0.1:30304" is available:
      1. Please close the Services window in your OS(if it is opened) and uninstall the V-Ray Online license server from your Start menu>Control Panel> Add remove programs
      2. Make sure to delete the folder C:\Program Files\Chaos Group\VRLService
      3. Go to the folder "C:\Program Files\Common Files\ChaosGroup" and delete all files and folders except "vrlclient.xml", which is needed.
      Please download and install the latest V-Ray Online license server 5.2.2 from our web site:
      https://download.chaosgroup.com/?platform=47&product=48
      After the installation is completed, please check if the V-Ray Online license server status page "localhost:30304" or "127.0.0.1:30304" is available and you are able to click "Online licensing" > Enable and enter your credentials.
      Let me know if the above suggestion helped you.
      Stefan Isakov
      Technical Support Team Lead
      Contact Support
      Chaos
        Sorry but I do not understand your instuctions - I am on a mac and in applications have a ChaosGroup folder not sure where else I should delete
          For Mac OS, please follow the below instructions:
          https://ftp.chaosgroup.com/Download/...structions.pdf
          After that, you should be able to open the http://localhost:30304 page and activate your license.
          Stefan Isakov
          Contact Support
          Chaos
            I still cannot access my license
              Ýou can start Team Viewer application and send me the ID and password for your Team Viewer in order to connect and check. if you are not ok to share such information here, you can send us an e-mail at support@chaosgroup.com
              Thank you.
              Stefan Isakov
              Contact Support
              Chaos
                Hi, I am having the same problem - "Could not obtain a licence (-200). The ChaosGroup Licence server could not be reached."
                I have followed the instructions above, uninstalling and reinstalling the V-Ray online licence server, but it did not fix it.
                Thanks.
                  Try reinstalling the license server.
                  If you still have issues after please e-mail us at support@chaosgroup.com
                  Ivan Slavchev
                  SysOps
                  Chaos Group
                    You save my life with this post...
                    thanks!!!
                    Windows 10 update break me.
                    Incredible...
                    Thanks
                    i ll be back
                    http://www.vincent-grieu.com
