We have two workstation licenses that won't work right now, despite me upgrading on one and restarting the workstation. Render nodes work, but is the server down????????
License Server Down? Issue V-Ray Next for Maya
Hello,
A CRS file is required only if you want to activate an Offline license server. The crs file can be generated only on a machine that has no Internet connection. According to our database, you were able to borrow 1 Interface (GUI) license on machine DellOne-PC. In order to use V-Ray, you require both an Interface and Render node license, you cannot use V-Ray only with an Interface license. I have released the borrowed Interface license, you should be able to use or borrow it again.
The Borrowing process is described on the following page:
https://docs.chaosgroup.com/display/...or+Offline+Use
You need to go to the Chaos License server page (http://localhost:30304), click on Online licensing then on "Use Licenses Offline". Follow steps 1 to 5, from the aforementioned link. You need both Interface and Render node license, in order to use V-Ray.Nikolay Simeonov
support@chaosgroup.com
Chaos Group
This is still happening. I've tried running separate versions of V-Ray entirely on all machines with the same issue, as the old version you installed of the License Server did not work. Render nodes "V-Ray error: Could not obtain a license (10061)". Even tried a separate test file, no luck.
Using a borrowed licensed, do I need to do that on all 11 render nodes or just for the machine running the License Server?
Originally posted by gfmarsh View PostThis is still happening. I've tried running separate versions of V-Ray entirely on all machines with the same issue, as the old version you installed of the License Server did not work. Render nodes "V-Ray error: Could not obtain a license (10061)". Even tried a separate test file, no luck.
If you still have problems after - please message us at support@chaosgroup.comIvan Slavchev
SysOps
Chaos Group
Thanks for directly helping me out Ivan. This all stemmed from overusing the amount of licenses I had. I didn't realize that the V-Ray frame buffer uses a render node license when in use, so it started my misdirected trouble shooting the license server. Then things got reset to the wrong settings a few times. It was a sad comedy of user errors. I have since bought another render node license, and so far so good. THANKS!
