Problem with starting VRLService [VRay for SketchUP / Windows 10]
  • Problem with starting VRLService [VRay for SketchUP / Windows 10]
    Hi, the VRLService didn't start after "cgls_win.exe" or "vray_42003_sketchup_win.exe" installation. I tried versions 5.2.3, 5.3.0, 5.4.0, 5.5.1 of cgls and the same error occurs.
    Below is log from installation window:
    Code:
    [SC] ControlService FAILED 1062:
    Usługa nie została uruchomiona. (Service does not start)
    [SC] DeleteService SUCCESS
    [SC] CreateService SUCCESS
    [SC] ChangeServiceConfig2 SUCCESS
    [SC] StartService FAILED 1053:
    Usługa nie odpowiada na sygnał uruchomienia lub sygnał sterujący w oczekiwanym czasie.
    (The Service did not Respond to the Start or Control Request in a Timely Fashion)
    Before this i have installed vray_42002_sketchup_win.exe and everything worked fine until reinstallation some days ago.
    I tried to clear old folders also.
    When i trying to run vrol.exe in commnd line this error occurs:
    Code:
    "component":"app",
    "config":{
    "host":"0.0.0.0",
    "por t":30304,
    "data":{
    "directory":"C:\\Program Files\\Common Files\\ChaosGroup"
    "dongle":{
    "enabled":false
    "ba ckend":{
    "portal":"https://ols.chaosgroup.com"
    "proxy":{
    "type":"none"
    "diag nostics":{
    "file":"C:\\Program Files\\Common Files\\ChaosGroup\\logs\\user.log",
    "level":"debug",
    "size":0
    "monitoring":{
    "traceProbability":0.01,
    " stackdriver":{
    "integrator":{
    "file":"C:\\Progr am Files\\Common Files\\ChaosGroup\\config.yml"
    "message":"Startin g Chaos License Server",
    "os":"Windows",
    "severity":"info",
    "time":"2 020-11-19T14:59:24.418299+01:00",
    "version":"5.5.1"
    "e":false,
    "error":"error reading machine secret: serial number could not be obtained",
    "f":"C:\\Program Files\\Common Files\\ChaosGroup\\config.yml",
    "i":"25a1b607-fa10-43fe-8d5b-46da60389a72",
    "message":"Error running license server",
    "severity":"fatal",
    "time":"2020-11-19T14:59:45.5490134+01:00"
    Thanks for any suggestions.
