Vantage License Error -197
  • Vantage License Error -197
    Hi all,
    Having some trouble with Vantage licensing today. It was working perfectly before.
    I've tried uninstall and install again with same localhost:30304 server and still no luck.
    I'm also logged in with the correct license account.
    Is this something you can do to help please?
    Thank you in advance!
    Andre
    I am afraid,that I am not able to alocate any Chaos Vantage licenses in our database, which is tied to your e-mail.
    I can see that the e-mail address have only V-Ray for 3ds Max license.
    In order to work with Chaos Vantage, you will need to apply for it on the link below(make sure to use the same e-mail as your other license, because you can not activate two users at the same time):
    https://store.chaosgroup.com/commerc.../chaos-vantage
    After you apply, please make sure to check the system requerments:
    https://docs.chaosgroup.com/display/...m+Requirements
    Then please go to our downloads section in order to download and install Chaos Vantage:
    https://download.chaosgroup.com/?lic...=-1&product=63
    You can check the below install instructions:
    https://docs.chaosgroup.com/display/LAV/Installation
    Make sure that V-Ray license server is installed and you activate the license with your username/e-mail tied to your license on the web page "127.0.0.1:30304"
    Let me know if you need further assistance.
    Stefan Isakov
    Technical Support Team Lead
    Contact Support
    Chaos
      Hi Stefan,
      Thank you very much!
      I thought I've applied with this account. Its working fine!
      Thanks again!
      Andre
