End User Licence agreement failed
  • End User Licence agreement failed
    hi,
    After updating to the latest version /vrY 52001 for sketchup win/ I can no longer access vray.
    Is there something I have missed during the update?
    I've got the same issue and I've uninstalled both SketchUp and V-Ray trying to start from scratch and still this error persists. I'm on Windows 10 / Skp 2021.
      Hello, Jamie and Michael,
      Apologies for the inconvenience this problem has caused!
      We have just identified its cause. Our dev team is currently preparing a solution that will be included in an upcoming hotfix!
      For the time being you can work around it by typing in %APPDATA% in the Windows File Explorer, then create a folder named Chaos Group at that location. Next, open the newly-created "Chaos Group" folder and create one more named V-Ray for SketchUp.
      The final path should look like this: C:\Users\user\AppData\Roaming\Chaos Group\V-Ray for SketchUp
      Once this is done, please relaunch SketchUp, accept the EULA and everything should work fine.
      Kind regards,
      Peter
      Peter Chaushev
      V-Ray for SketchUp | V-Ray for Rhino | Product Owner
      www.chaos.com
        While the v5.20.02 hotfix update is still underway, a solution is now available in the following stable builds:If anyone else experiences the described issue, please download and use the respective installer.
        Peter
        Peter Chaushev
        www.chaos.com
