Chaos License server online activation
  • Chaos License server online activation
    Hello!
    I am trying to activate my licenses with Chaos License server, but my office has Firewall protection.
    CMD command
    HTML Code:
    tracert ols.chaosgroup.com
    fails. Can you please tell me what port for
    HTML Code:
    ols.chaosgroup.com
    do I need to provide for the Firewall?
    Thank you in advance!
    Our license server uses its own private certificate to encrypt the connection to our back end server. Its a self signed certificate and nothing should modify it or block it so it must be allowed in the proxy/firewall configuration. The certificate is located in C:\Program Files\Common Files\ChaosGroup\ssl for 5.x.x servers or in C:\Users\USERNAME\AppData\Roaming\Chaos\VRLService \ssl folder for versions 6.x.x. Also both addresses https://ols.chaosgroup.com and https://accounts.chaosgroup.com must be allowed in the proxy/firewall as well as the https requests and port 443.
    Kostadin Botev
    Contact Support
    Chaos
