No License available
  • No License available
    Hi
    I've no license available from yesterday. None of Vray works and I have raised a ticket this morning but I have not had a response.
    My ticket is 127518
    Kind regards
    Hi, thanks for posting. Your issue will be resolved trough the ticketing system. Apologies for the inconvenience this issue might have caused.
    Vladimir Krastev | chaos.com
      Hi
      Thank you for your reply.
      Do you know roughly how long this will take to get to my ticket number?
        Hi
        I'm supposed to have a remote session this morning 8am UK time with Stefan to go through the installation, but I haven't had any communications so far.
          Have you checked this solution?
          https://forums.chaos.com/forum/licen...online-license
          Best Regards
          Tomek
          Portfolio: http://dtown.pl/
            Thanks Tomek,
            Unfortunately it was zscaler that was the cause of the problem. The company had just recently installed this and problem saw my license as threat so it got removed?? Had to disable for the license to work.
              Good that you had it sorted out!
              Best Regards
              Tomek
                Hello,
                http://localhost:30304/ is not responding where I used to activate my licence.
                On my computer, no firewall installed, no antivirus I also re installed chrome to see any cache problems, I have both corona and vray licence but both doesn't work . I uninstalled the vray and chaos server, then installed the newest ones from the chaos website but still can't register. Also at the end of the chaos server setup it gave an red written error to install manually licence. I tried stop the chaos server delete the ssl folder and start again but it doesnt work either.
                Can someone let me know what to try next before support contacts me?
                Many thanks
                Bora
                I
                  Hello Bora,
                  I recommend you open a ticket in our system, so we can further help with your issue.
                  It seems that the license server is not started for some reason, and we will need to check why?
                  Sometimes after a Windows update the license server components are changed and need to be fixed.
                  Please follow the link below in order to open a ticket(make sure to choose "Technical assistance starting the product"):
                  https://support.chaos.com/hc/en-us/requests/new
                  Thank you.
                  Stefan Isakov
                  support@chaosgroup.com
                  Contact Support
                  Chaos Group
                    Now it is sorted by the help of support,
                    many thanks
                    Bora
