Could not obtain a licence (-200)
  • Could not obtain a licence (-200)
    I started up Max, loaded a scene and when I tried to render in Vray. I got "Could not obtain a licence (-200)". On trying to open localhost:30304, I got "Unable to connect". I use online licensing, so do not have a dongle. I checked Services and the licence server is running... Not sure what else to do. It was working just fine earlier today. but now this
    Hi Andy,
    Please try to following:
    1. Uninstall the V-Ray Online License Server from "Control Panel" -> "Programs and Features"
    2. Delete the "C:\Program Files\Common Files\ChaosGroup" folder
    3. Install the latest release of the V-Ray Online License Server: https://download.chaosgroup.com/license-server
    Afterwards try to open http://localhost:30304 and if you are still getting licensing issues please send the logs from C:\Program Files\Common Files\ChaosGroup\logs to support@chaosgroup.com in order to troubleshoot the issue further.
      Sorry for the late reply, got called away and only just got back... Anyway I followed your instructions and all is good again, so thanks for that Milhail.. was in a bit of a panic there..
      Also turns out it may have been caused by the latest "Feature update for Windows 10 1709" and if true, this may help others cure this problem.
        I am having the same problem on OSX
        installed (and reinstalled) the latest LC-version
        are there some helpful hints for Mac please
          Hello,
          Can you please set the "V-Ray Client License Settings" to point to 127.0.0.1 and port 30304
          Do to so you will need to run the "setvrlservice" with the parameters -server=127.0.0.1 and -port=30304
          For more information on how to do it please check the documentation here:
          https://docs.chaosgroup.com/display/...ettings-MacOSX
          Additionally please make sure that the firewall (or a third party application) is not blocking the access to port 30304 on your machine.
          Afterwards you can restart the 3d application and try to render with V-Ray.
          If that does not solve the issue can you please let us know what is the 3d application that you are using, the exact version of V-Ray that you have installed and if you are able to access the license server at http://localhost:30304
