Animator Workstations Pulling Licenses Upon Startup
  • Animator Workstations Pulling Licenses Upon Startup
    Our studio seems to be having a strange issues with licenses, which we only started having after upgrading our Vray to 3.6.02
    Normally, we have enough Vray licenses for only our lighting team, even though we install Vray on our animation workstations in order to have Vray nodes load properly in Maya for our animators.
    This has been working out perfectly fine since Vray only pulls a license when you actually hit the render button. After we updated, however, the animator workstations started pulling licenses just by loading up a scene file with Vray nodes in it.
    My question is: Has there been a change to when Vray pulls a floating license?
    Is there a workaround for this? (Perhaps a way to blacklist Animator machine from pulling a license, while still having Vray loaded so they can properly work in scenes that have vray nodes in them).
    Is this a situation where we would need to have more licenses for animators, even though they are not rendering with Vray?
    I would appreciate some clarity on this.
    Thanks much!
    -ChrisB
    its probably drawing a license to refresh shader thumbnails (just a guess) You may disable thumbnail update and see if that solves it.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Dmitry, Good thought!
      I checked it out, though, and it looks like thumbnail update is already disabled on some of the animator workstations which were pulling a license.
      Thanks for the input, much appreciated.
        whats your license server version? theoretically and this is how it works for me, it only calls for license when you render, not even when working in UI. For example right now I have maya open and vray loaded but license server shows 0 engaged. I have lic server 4.4.1 be sure you have latest.
        Dmitry Vinnik
        ShowReel:
          Looks like we are running 4.3.1
          I'm going to have I.T. update our license server to see if that helps.
          Thank you,
          -ChrisB
            Additionally if that also does not solve your issue, you can update your dongle wibiu drivers here https://www.wibu.com/
            Dmitry Vinnik
            ShowReel:
