Hello,
Im new here. I know im not in the right section of the forum, but i dont have the "post" button on the other section, i dont know why?
My question is about the vray framebuffer. When i use the exposure correction, often, i have bad edges on the alpha, on after effect. If i save the same image, without the exposure correction (of the vray frame buffer) its clean.
Both render are on black background. On after effect I add the blue background. You can see the with edge on the leaf, on the corrected version. Its not clean.
Is there a solution?
I have already tried to do the exposure correction in after effect, but i dont succeed to have the same results as the vray framebuffer exposure correction.
Thank you.
Thank you.
