Could Not Obtain a license (-7) - License server denying access - Only happens when DR....
  • Could Not Obtain a license (-7) - License server denying access - Only happens when DR....
    We have ten nodes that run fine for sending renders to and using DR. We added two render pro and can send renders to them without any issues. However, when we try to use either of the new render pro nodes individually or together for a DR we get the following error.
    "could not obtain a licence (-7). The Chaosgroup server is denying access.
    Not sure why this is occurring only during DR. Any ideas?
    Thanks in advance.
    Make sure that a firewall on the render node computers is not blocking TCP port 30304. Also - the license settings should be adjusted to point towards the license server computer - https://docs.chaosgroup.com/display/...cense+Settings
    Last - check the status page of the license server for free render node licenses before you attempt a render - http://IP_Adrress_of_the_license_server30304
    Ivan Slavchev
    SysOps
    Chaos Group
