Notable changes in this version:
- .vrimg support;
- Four more settings for the frame indicator: frame from name, embedded frame number, embedded time code, embedded egde/key code;
- 1D look-up table support;
- Various mask and command line improvements.
The full change log since 1.0.1.10 follows:
- .vrimg support;
1.0.1.17:
x64 fixes.
1.0.1.16:
Added --layer_position_after, --timeline_fit_all_layers, --timeline_trim_to_workarea (#154, #155, #156)
Added --still_image, which export to pdpcmd now uses (#158 )
Audio is now started if a WAV file is passed on the command line (#157)
Frame number and key code are read from CIN files
--toggle_layer_stack added (shortcut Q or double click at the edge) (#164)
1.0.1.15:
1D look-up table support (#83)
1.0.1.14:
Double-click on the mask size allows one to enter a custom mask (#137)
"Apply aspect to mask" now applies pan and zoom as well (#86)
1.0.1.13:
Alternative slider drag speed is now activated with Alt+drag instead of Shift+drag
Decreased the default drag speed of lift/gamma/gain for finer control
1.0.1.12:
The frame/timecode indicator now has four more settings: (#153)
- Frame from name
- Embedded frame number
- Embedded time code
- Embedded egde/key code
Frame number, time code and edge code are read from DPX files
Frame number is read from RLA files
Time code and key code are read from EXR files
1.0.1.11:
.vrimg support added (#139)
Improved handling of some malformed AVI files (#147)
Color controls changed to handle negative (darker than black) colors better
In particular, the gamma is now applied after lift+gain
x64 fixes.
1.0.1.16:
1.0.1.15:
1.0.1.14:
1.0.1.13:
1.0.1.12:
- Frame from name
1.0.1.11:
