Can we set the compression level for jpg output?
  • Can we set the compression level for jpg output?
    Hi.
    I love pdplayer! Save use soooo much time.
    On thing is missing for me, be able to set compression level when outputing the final result...
    Save mask as sequence... No way to adjuste the jpeg compression ????
    Regards.
    _____________
    OZRAY, 2009.
    I'm glad you like Pdplayer.
    You're right that currently we offer no way to adjust the JPEG compression level; it's fixed at 85. I suspect you'd like to increase that.
    I've added your request to our feature tracking system and the ability to set the compression level will appear in one of our future releases.
    (For those interested in technical details, the reason that this is not trivial to add is that our image savers currently do not take parameters so this support will require some restructuring.)
    Peter Dimov
    Asynthetic
    www.pdplayer.com
      The upcoming 1.0.2 release will allow one to set the JPEG quality.
      Peter Dimov
      Asynthetic
      www.pdplayer.com
