Make sure there isn't a color space mismatch (if using linear image formats, set Color Space to Linear, etc.). Also, note that images in PDPlayer are converted to log space before LUT application (more accurate than Linear space for this purpose). There may be a mismatch if the LUT application is applied differently in DaVinci. Otherwise, could you share an image to test with and some screencaps of the differences?
