We're using the (32 bit so far) trial of PDP.
I'm facing some serious stuttering while playing back. The CPU is a Q9450 (shouldnt be the issue), the footage is SD, graphics cars is a QuadroFX 1700 with the latest drivers.
The sequence is pre-cached, so no disk traffic occurs while playing back. Setting the "synchronize" options doesnt help, every 20 frames or so I encounter stuttering (like one or two dropped frames, no tearing).
It also occurs when playing the sequence back with 60fps, so it's not a "25fps sequence on a 60fps display"-issue.
Any ideas? Other players on the same syestem dont show that behavior.
Is there a way to activate a logfile to see where it stumbles?
*Edit: Just switched over to the 64bit trial edition, same issues. The trouble increases tenfold, when going to fullscreen mode. It runs completely out of sync even with footage as low as 640x480
