Suggestion: sequence parser should recognize irregular sequence tokens
  • Suggestion: sequence parser should recognize irregular sequence tokens
    Right now the sequence parser correctly recognizes a sequence which is named like pic.0001.exr to pic.9999.exr
    However if the sequence token is broken, like pic.1.exr to pic.9999.exr it only recognizes .1. to .9. as a sequence.
    While this has been the case for a lot pf players in the past, these days everyone recognizes it as one sequence without the need to rename it previously.
    I agree that this is a reasonable suggestion and will add it to the list of things to do.
    In the meantime, you should be able to open such sequences by dropping the folder containing the sequence onto the Pdplayer window. This works for other irregular naming conventions, too.
    Peter Dimov
    Asynthetic
    www.pdplayer.com
