The sample compositions dont get downloaded
  • The sample compositions dont get downloaded
    http://chaosgroup.com/en/2/pdplayer_downloads.html
    I tried downloading a couple of the sample compositions and had no problems doing so.
    Could you specify which compositions exactly you have issues with.
    You can also try to download the sample compositions from here.
    Regards
    Jimmy
      Sir i am having with all.
      Only the file gets downloaded and not the contents in it....
      I mean the empty pdfile.
      Thanks
      regards
      savio
        Still am not able to download..................only the empty pdplayer get downloaded.
          Its very sad no one from chaosgroup can give me a solution......
            Can you tell us which version of Pdplayer you are using and is it trial or full version.
              Its pdplayer 64 1.0.5.9
              its a license copy....
              Full version.
              Thanks man for helping
                Can you please try to download http://pdplayer.com/compositions/fade.pdpcomp and see if it opens? It should be 4,101,234 bytes.
                Edit: We've moved the downloadable content to another server; please visit www.pdplayer.com/downloads.html again and see if it works for you.
                Peter Dimov
                Asynthetic
                www.pdplayer.com
                  Thank u so much the links are getting downloaded now........
                  Thanks for the support..
